Wow, how pricey is this vs going electric hydraulic.
Also is it the ram that's slow or the air motor or little bit of both. Thank you
Pricey is an adjective that is open to personal interpretation and perspective.
My spx power pack runs several different tools I have. Quick detach no loss hydraulic couplers on items.
It’s definitely not cheap or homebrew. It is professional level stuff and dependable. I also didn’t have to figure anything out. Hook it up and use it. Works every time. I didn’t buy the setup new either.
I cannot speak about why the HF air/hydraulic system is slow, I can only guess.
Small air piston/motor to drive the hydraulics that’s not efficient. Almost anything air powered is going to consume a ton of air, bad for speed and efficiency but great for environments that require air or hydraulic tooling. (Think coal mine).
Could also be sub par air volume supply or could just be cheap parts.
I haven’t been inside one to tell you for sure.
If I had to build one from scratch, it would be electric motor driving a hydraulic pump with a manual valve with a metering valve for speed control.
None of that is super complicated just takes common hydraulic items to make it work and some math to get everything sized/specd correctly to be happy together.
Tons of info on web about diy elec/hydraulic tube benders.
My main point was that it’s not fair to say air/hydraulic sucks. They aren’t all equal. Building from scratch, do electric/hydraulic. Far easier and safer than air/hydraulic. The air in these systems acts like a spring. On diy stuff with high pressure and volume, you can get hurt easily.
I guess I’m trying to say bigger safety factor doing diy elec/hydraulic than air/hydraulic.
If I had to guess, I could probably do 90* in about 15 seconds. Takes longer to get tubing in die perfectly and nail the rotation than to make the bend.
SPX Power Team 10,000 psi Air / Hydraulic Pump
This is very similar to my power unit.
Most of the rams are 2” dia or larger and below 6” stroke.
Pressure is the force applied to the ram piston. The power. Volume of flow is the speed you can move that piston.
High pressure low flow = high force low speed
Low pressure high flow = low force high speed
High pressure high speed = high force high speed
Multiple the pressure of the pump output (psi pounds per square inch) by the area of the piston ( sq inch) to get force of ram. Smaller piston equals less force. Larger piston equals more force.
Longer stroke needs more volume (flow) per unit time compared to a shorter one if psi is the same, for the ram to move at same speed (short vs long)
