- Mar 24, 2005
- Stanley, NC
Whats the best way to keep the tube level, and how do you get the right rotation angle on 3D parts?
Thanks in advance.
Thanks in advance.
Use an angle finder with a magnet on one side and a "V" channel on the other. It is a dial type that uses gravity and can turn 360 deg (looks kinda like a big compass but with degrees marked from 1-360). this will help greatly on finding your angles and always use a pencil and paper to visualize your bends, this will save you on scrap metal that you could have used on something else. Draw it out with a front, right side, and top view for best visualization (its called "third angle projection" if you need to google it). Oh and you can buy that type of angle finder at almost any hardware store, maybe even wallyworld.
on tv "extreme4x4" he use an exhaust clamp with a magnetic angle finder on top of it that way you could see the twist by the angle on the angle finder. would probable work best to mount an exhuast clamp on each end a keeep checking as you bend. NOt sure if thiis i what you are talking about since ive never bent a single tube
When I bought the bender, it was already vertical, with an air/hydro ram. I may make a clamp for my angle finder. That Wixey one looks really nice, but is a little out of my price range (and I will probably drop a die on it or something).First, turn your horizontal bender into a vertical, then throw on and air/hydro ram. You will be far happier. It's like saying "I can notch just find with an angle grinder", then buying a tube notcher. Second, buy a digital angle finder. The Wixey one works great. Everything else after that is simple. Just add or subtract angles. Or 0 the angle finder and go from there.
