turbo on a 4.0
jaybird1ton
The Flats Offroad Park
Marion
Was wondering if their was a kit or if anyone knew someone that has done it.Just getting an idea on how much trouble it would be and if it would even be worth it.I have a 99 xj.
Hello everyone, not trying to toot my own horn just though you may like some info and pics on a turbo kit I made for a customer up in PA. First of all the header can be a pain to fabricate but the results are quite impressive, you really need to make sure you have the motor to handle the added stress. With a low boost setting you should be able to drive on the street or trail with out a problem, especially if you run it on E85. The kit on the website is for an 87 Cherokee and everything fits under the hood, the turbo sits in place of the factory air box. To check out the turbo setup just go to http://www.newcomerracing.com
