southern4x4
- Nov 7, 2005
- Charlotte, NC
I am sure many of you already know this method of removing a stubborn u-joint but I just found this write-up today and it worked great...for getting 2 of the caps off and 1 of the shafts, not I am working on getting the other half of the joint out but I am running into the issue of not having enough room to get a good clean hit without hitting the collar that surrounds the yoke on the outter passenger side shaft for a dana 30. I dont want to damage the collar because honestly I have no idea what it is for and don't want to cause more repairs or trouble. Any suggestions?
Here is the link to the write-up
http://www.4x4wire.com/tech/axle/ujoint/
and here is a link to a picture of my shaft showing the collar. sorry that it doesn't show the space I have but believe me it isn't enough to fit any decent size hammer in there without hitting either the collar or the cap, which then won't let it slide out.
http://www.webwheeling.com/forums/showthread.php?p=20883#post20883
it is the 6th post
it is the 6th post
