Jeffncs
- Apr 4, 2017
- Wake Forest
I’ve been reading and reading about swapping a 4.0 from a ‘98 Cherokee into a 82 CJ7. Planning to use the 4.0 engine harness, PCM, and EFI.
The CJ7 has a stock 4.2 and a new, aftermarket wiring harness from Centech.
I can’t seem to find answers to the following questions.
1. Can I get away with using the minimum required wires from my harness to run the EFI / CPU / engine? I’m trying to avoid splicing and cutting the XJ harness if I can avoid using it.
2. The earlier 4.0 engines require a fuel return. however, the later engines supposedly don’t. Am I correct in saying that the 98 does NOT require a fuel return line? That seems to be what I’ve read.
Opinion question - 4.0 has ~200k on it and leaking oil. Should I just reseal it and drop it in? Or, should I just wait until the winter and get it rebuilt?
I’ll have more questions as i
