Uwharrie Trails
Jeepj10
Asheville/NCSU
I'm going to pick up a bronco II tomorrow and on the way home im planing on stopping by Uwharrie to test it out, Ive never been there before and was wondering what trails would be somewhat easy, I'm not looking to take it on crazy trails the first day I own it. Anyways, Its a Bronco II with a 6-8" lift and some worn out 35's, also has a swapped in Dana 35 in the front.
Any advice would be appreciated.
Ben
Anything but Daniel essentially. Everything else has bypasses, and Daniel does also except for the one ledge. If it had a bypass I would say do Daniel too. I bet your truck can do Daniel, but for a break in run I would say avoid it.
^^ What he said. Wolfs Den is the easiest trail there. I'd recommend starting out on it while you get used to the rig.
make a friend before you head down the trails. there will be somebody somewhere that will let you tag along.
dont go wheeling alone in a strange vehicle.
^^^that's the truth...hang out at the Eldorado Outpost Sat. morning...you should be able to meet up with someone in about 30 seconds.
I agree with all of the above!
Great
Perfect thanks for all the advice, we will defiantly see if we can meet up with someone doing some mild trails at the outpost. Looking forward to it.
Thanks again
Ben
Welll
Well my buddy that was going to come with me ended up not coming so I didnt stop, Im going to try and make it out there sometime in the next couple weeks
Ben
