waggy 44 maunal hub convertion?
Yes
is that all i need? cuz i send a pm to someone and he just replyed and he said " You will need to replace the hubs, bearings(given), rotors, and knuckles. If you are planning on replacing all that stuff, then the axle is ok. "
WARNING!!!!...
That dood's torque instructions for the bearing pre-load is wrong. I discovered that before I even rolled out on mine for the first time, but if you follow those instructions there's almost no pre-load (therefore, slop) and you'll smoke some bearings.
I need to find you the right Torque instructions
hey redneck-up, be sure to keep those stock drive flange gears in your trail box...if you break a hub just slap it in and you are locked again...this will keep a broken ub from ruining your trip..
if you already knew this just overlook
thanks
