RatLabGuy
- May 18, 2005
- Churchville, MD
So... aparently during the last ECORS race one of my u-bolts came prety loose, in the meantime the hold in the top of the perch got good and walowed out. A little on the other side too.
important lesson - always check your u-bolt tension!
now i know the *right* thing to do would be to cut off the perches ocmpletely and weld on some new ones, esp since I need to re-angle them for my pinion angle. But what a PITA for a backyyard guy like me.
What other options are there to fix this? I have a few ideas...
1 - weld in a bunch of new material, esenetially fill in the hole, then re-drill it out. I could see that re-drilling being a real pain though.
2 - get some 1/4" plate the szie of the perch, dril a hole it in, weld that on top of the perch. Essentially make a new "top" for the perch.
3 - Since I need to use shims anyway, just weld the shims to the perch, covering the old hole. Boy that woudl make lining up the axle/u-bolt/springs alot easier, but then the dergee of the shim is permanently in there. But, does that really matter?
