waterfall
bluecrawler
Member
wilkesboro
I am heading to Callalantee Sat. and am wondering where the waterfall is on the map. I rember it being close to the campground but may be wrong. Can someone show it on the map or give me a general of its placement on the map.
If you follow the green trail out of the campground, it will be the third black trail on the left. It's called the Welder trail. The entrance is marked on a tree on the left of the green trail pointing up into Welder. The waterfall is just a short way into the trail. Someone please chime in if I'm wrong here.
My crappy edit of the map. Should give you a general idea of where it is. Welder will split rt and left at the obstacle. Left to bypass it and right to go to Waterfall.
It's a little further up the trail than the arrow shows...but you can't miss it once you get on Welder.
I'm not familiar with the area at all. Are these actually "trails" or unimproved roads? I'm always looking for waterfalls, and if I can do it without tearing things up, I'll add it to my list.
