profile says - 1986 Jeep, CJ-7 so im guessing a 4.2
are you attempting to tune it your self ? or drop off service ?
for self tuning, we'll need some more info to help you out...
but some things id check first..
1) Base Timing, needs to be set right..
2) Advance make sure your getting enough advance that will cause poor performance with any carb.
3) check for other issues, cap/rotor plugs wires etc..
for those reading along - 32/26 is a progressive 2 bbl. 1 bbl is normal and the other is the secondary, almost like a 4bbl cut in half sideways vs the normal across....
so its relitivly easy to do some base adjustments... slap a vac guage on the engine and adjust the carb so you pull the most vacume at idle..
start with that and then report back with the following..
is it rich at idle?
pep, as in acceleration ? black/blue smoke when accelerating ?
does it boog then pick up ?
