I have a small Lincoln that welds flux or mig. It was working good on flux and I ran out of wire so I switched to mig. Now its poping and wont weld for crap. The flux wire was .30 the mig is .25 I changed ends,cleaned the gun,adjustde the wire tension,speed and heat range. With the flux I was running the heat half way up would burn thru if I slowed down to much with the mig I can run it wide open and not burn thru. I'm welding sheet metal patchs. I got the small gas bottle because I dont weld much with the wire welder but the dang thing ran out of gas before I could get a good bead. I have played with it for about 2 hours adjusting and trying to weld. The gas should last longer than that shouldnt it ? The 10lbs spool of flux wire has lasted me about 5 years. HELP
Allen
Allen
