Wire speed is the key, i've welded on everything from tractors to frames an trailers never had a failure, I run a Iron man 210. Practice x practice, I have an old man for a pal, he can weld with coat hangers better than most can with high dollar equipment, knowledge of welding comes from years of technique an knowing how different structures will act when welded. Size of wire matters not, case in point a fillet weld takes several passes, instead of being globbed on like bird shit, you can weld anything with a 1/8" rod that can be welded with a 3/16" rod, time is the issue, I like the versatillity of the smaller wire, from thin sheet metal to 1/4" without changing wire. If I have to make a couple of passes it does not bother me. If you want to see a weak weld try pushing 035 wire through a 110v machine, that shows lack of knowledge in welding with penetration an a bad temp. It does not matter what the manual that comes with it says, these machines can not drive that kind of heat range. If you don't beleive me weld up a couple of 3/16" plates an grind out your weld a little at a time an stress it, you will find your weld I promise you.
