iwaxmyjimmy
College Web Wheeler
- Mar 10, 2007
- Greenville NC
I do a few ring and pinions a month it seems lately, ive done quite a few in life time between working at dealerships, my stuff, friends rigs, and my little bullshit business out of my garage. I’m no Jody Treadway by any means, he’s who I go to if I have questions and secretly I wear crocs trying to channel my inner axle Yoda before I message him so I don’t ask a stupid question. Did that a few months ago, as I was digging through shims and found a master shim so I could take out a few thousandths off the pinion shim, it was a oof moment. Anyway, this is the first time I’ve ever had to go to this length to remove one. Generally I use a punch bit in my air hammer and it drives them out without a problem. I apologized to the customer because again this is a first for me, and I knew it was gonna trash his factory pinion gear, thank god he’s going to 4.88s. Anyway here are some pics.
First few wacks demolished the nut on the end. Took the nut off, advised my customer what I was gonna have to do and it wasn’t budging. Pulled the rear housing and threw it on my axle stand and chained it down.
Tried a map gas torch to heat the bearing up hoping it would budge. I got all of 1/8-1/4” of movement out of it. Arms were spent, so grabbed the plasma cutter. Worse case I’d have to source another rear housing.
Still took 10 good wacks with the 4lb sledge. Now my veins are a nurses wet dream. Now to clean up the pinion seal surface some and setup these 4.88s. Just figured it would be interesting and I’m sure someone has an alternative method. I’m currently swamped because the local shops can’t put out decent work.
