What caliper for rear disc set up?
89wrangler
Not a new member
Bostic,NC
What calipers do most use for rear disc set ups? I purchased my 14B rear already set up with disc brakes and I have a bad caliper. I know I will get the deer in th headlight look is I don't have a vehicle model at the parts store. I am going to take mine with me, but maybe knowing a model or two will help expedite the process. Thanks
If its not an ebrake caliper I usually use a front caliper for a 77 chevy k20 on my 14b
Sent with two cans and some string.
Can also use the half ton stuff as well. I'd always seen people using 75 k10 or k20.
Sent from my mobile Toyota base using Tapatalk
Thanks guys. It is a non e brake so I will start those when I head up toen.
Well the 78 C20 caliper worked. Had to grind a little hump back about a 1/4" but all is good again.
