What Gearing options? 92 tracker
The#1Dakota
Salisbury
Currently I'm running 5.13's 5spd 1.0 high & 1.816 low range stock T'case. 1st gear is 3.652 Running 33/12.5/15
I have found 3 gearing options so far.
1. The Undertaker (basically a gear reduction box goes between trans and t'case). 1.5 to 1 Underdrive affects low and high range. $1295
http://www.lowrangeoffroad.com/suzuki/sidekick-tracker-x90/drivetrain/undertaker-sidekick-tracker-underdrive.html
2. 4.24:1 Transfer Case Gears Only affects low range $649
http://www.lowrangeoffroad.com/suzuki/sidekick-tracker-x90/drivetrain/sidekick-tracker-vitara-4-24-1-rockmonster-transfer-case-gears.html
3. Which looks expensive, "Kicker 2" and will take fab work but will be durrable.
http://www.ottindustries.com/kicker2.htm
Has anyone tried any of these gearing options? What would u recommend?
Leaning toward Undertaker or 4.24.1 gears at this point.
Thx.
