what is wrong with my jeep?
jeep9mm
Charlotte, Wilmington
Who? 2004 Jeep Wrangler 2.4 4 cyl 5 speed
What? As of the past two weeks I have noticed my jeep has no power at low speeds and low rpms. For example, when im in first and start moving, sometimes I have to push the clutch back in to not stall...the gas seems to not kick in until later. A better example is this...say you are in a parking lot in second gear and you slow down to go over a speed bump and stay in second...once I clear the bump and hit the gas the jeep just wont respond, kinda sounds like its close to stalling, and then itll pick up and act normally. If you dont slow down...it drives normally.
Fuel pump? I really have no idea...what do you think?
hmm can the sensor be adjusted or if thats whats messing up it needs to be replaced? Who does this kind of work besides the dealer...i dont think they like me at my local one.
cat clogged, fuel pump, lots of options. is there a check engine light? How many miles on it?
If it's the TPS you can change that yourself. Have you considered maybe a coil pack is going bad. Find someone with a year similar to yours and swap them over and see what happens
