looks like all of them, in a dana 30 has the #s 85037. and its in it in a axle geared 456, will it work in my axle geared 4.10, and is it hard to install. thanks
I think there's only one part number for each brand of lockers that fit most D30's. I would bet it would work. If the ring gear overlaps the area where the cross-shaft comes out, you will need to pull the carrier and remove the ring gear. I did my D30 with 4.10, but had the whole axle apart anyways; I can't remember if the cross-shaft was blocked or not.
