Clubbs
- Jun 15, 2008
- Blounts Creek
Gathering parts for the 440 swap into the cj. I've the engine and a torque flight 727 trans that's mounted to a 203 tcase.
The 203 is a unique input and trans adapter so I'm picking up a jeep 727 tomorrow that has the standard round pattern and 23 spline output shaft. I'll swap the shaft and adapter into my big block Mopar trans.
I was figuring on two scenarios: use the stock Dana 300 from the jeep since it will bolt right up, but it's so small I think the front driveshaft will hit the trans pan even though I'm running a full width Dana 60 front. So I was just going to use a dodge np205 instead.
I'm not sure but it looks like the dodge np205 has the same figure 8 input bolt pattern as the gm box. And if so it has an adapter to convert to the round 6 bolt pattern that will be on the trans. Is that true? How long is this going to be?
I have a gm 32 spline big bearing 205 case I was going to use as a doubler with my 203. That's a long package for a cj, but it may be close to the 727 adapter to adapter to 205 I'll have to run anyway.
Anyone got any pics of a dodge 727 with a dodge 205 bolted up? I don't think I can use my big bearing 32 spline input gm 205 even if I change the input shaft because the big bearing won't fit in the adapter. Any ideas or confirmation on either of those questions would be appreciated
