jput New Member Joined Mar 20, 2006 Location Morganton Mar 24, 2006 #1 Hey all looking for infor on tire size, just lifted my TJ 4" short arm and 1" body lift will 35's work or should I stick with 33" tires.
03jeep Active Member Joined Mar 20, 2006 Location Lexington SC Mar 25, 2006 #2 I would say you could run 35s easy. I ran 35s with a 4" suspension 2" spacer and 1.25" body with short arms and did fine and I also have a buddy doing the same and we just got back from Tellico and his did great. DJ
NCJeepin Well-Known Member Joined Mar 23, 2005 Location Conway, SC Mar 25, 2006 #3 yeah 35's should work, but 33s will give u near bout as much flex as your suspension would handle... but the 35's wont take too much away from it
Mr_DIY New Member Joined Jun 23, 2005 Location Smithfield, NC Mar 25, 2006 #4 I say trim sheetmetal and put whatever your axles can handle
jput New Member Joined Mar 20, 2006 Location Morganton Mar 25, 2006 #6 Thanks all looks like it will be 35's better axles on order and i do have a sawsall if i need it
uglyjeepoffroad Registered Loser Joined Mar 20, 2005 Location Hickory, NC Mar 27, 2006 #7 If you have a dana 35, it won't last long with 35's.
GSW Well-Known Member Joined Mar 21, 2005 Location Granite Falls, NC Mar 27, 2006 #8 Don't forget upgrades to your gearing, brakes and steering if going with 35s.
Yay!Gurrr Better Faster Stronger Moderator Joined Mar 17, 2005 Location N. N. Raleigh, NC Jun 2, 2006 #10 jput - with some more information you might get some input better suited to your needs.. is it you DD also ? do you trailer it? do you have street tires to swap on ? what gears ? stock axles?
DOUGHBOYDD2500HD New Member Joined Aug 3, 2005 Location RTP Jun 2, 2006 #11 HMMM I would go with the new 47 inch LTB's. They are awesome
Ridgerunner Well-Known Member Joined Mar 21, 2005 Location Fuquay Varina, NC Jun 2, 2006 #12 uglyjeepoffroad said: If you have a dana 35, it won't last long with 35's. Click to expand... yup 35-35=0
