What springs to use for flex
Bullardbs
Thomasville, NC
I have 79 Bronco with 4 inch lift springs from skyjacker on the front and they dont flex much at all. Just wanted to see what anyone had to say about what to use to get for flex.
I saw them on broncograveyard the ones that say FLEX not sure how I missed that thanks for the input
thats the ones. superflex
as you can see, they work pretty good.
thanks that is what I would like mine to look like where did you get the tube doors or did you make them?
I'm running the 6" superflex coils on my SAS '95 bronco. Made by Deaver and found them on broncograveyard.com. I'd recommend them also. You won't find anything better for your application. They do make them in a 4" version, too.
Here they are in some mild action. I'm running Cage radius arms, too, as was Mike in the pic a few posts earlier...
VIDEO:
I have the rock crawlers from WH and they are pretty good, but like Johnski said...I think they only cater to the EB's,Chuck
Thanks for eceryones input I think I have the front covered but what should I use in the rear. It has stock leafs now and lift blocks. I want to put lift springs in but what brand would you recomend?
I saw the ones on Broncograveyard.com that are for flex but is there a cheeper set than 500 + shipping
