what will the outcome be
brettandcrystal
lenior,nc
I have 84 ford f150 302 4x4 setting on 35''s. i going to put 4.11 front and rear. to replace the 3.00 gears.
Swap the 2 barrel for 4 barrel 600 or750 cfm. New in take new cam 282 duration 498 lift. the motor is a crate motor falirly new so mabye not any major bottom end work. will this upgrade be worth it. its still some what of a daily driver. thanks for the input
Are you sure you have 3.00 gears? I ask because most 1/2 ton fords from that time had 3.50/3.55 gears.
