trailjeepman
- Jun 7, 2005
- Raleigh, NC
OK.....I have had stopping issues for a while now. I have an 83 CJ7 with power brakes on 35's and geared 4:10. I has always seemed as if I just have manual brakes.
So this weekend I changed the master cylinder to one for a 84 Suburban with JD7 brakes. This is a bigger bore master cylinder and hoped to help with stopping power. Well it didn't. And before you ask, I did bench bleed it and have bled all the lines. I do have a very stiff pedal. I also changed the combination valve but that didnt help either. The brakes feel the same as they did before I began.
I also started thinking that maybe my booster is not working but I am not sure.
I read in the haynes manual how to check the booster by pumping the pedal a few times with the engine not running. Hold in the pedal and crank it. It says the pedal should give way toward the floor. Idid this and it did give way a little but not much.
My question is....Do you think its my booster? If not then what else could it be.
Thanks
Nathan
Thanks
Nathan
