highrollintj
- Nov 13, 2005
- Rolesville
i just want to see who else here has had bad experiences at or with the dealership and what they did to make you "dislike" them.
i just put my jeep in the shop for some warranty work, but they find every loop hole around the problem as to why it isnt covered under the warranty. and the service manager at the dealership i went to used to work at a different dealership and he told me one thing, but now says that he didnt tell me that, so it is my word against his.
an o ring went out in my t-case but the ring isnt covered by my extended warranty, which really doesnt botter me cus i can replace it myself and if you had heard how much they wanted to charge to replace it you might have fainted.
the next issue was the front drive shaft u joint which i had no idea was bad, but apparently it is messed up. they want cover it under the warranty because of my lift. but when i asked how the lift could have effected the part he changed subject to how much mud was under my jeep and how that had some effect. however there was no mud on the part. they want to charge $65 for a new u joint which is outrageous and then on top of that like $90 for installation. my was not a concern the last two times my transmission had to be fixed or when my rear pinion seal went out and they had to replace my entire rear end.
to make a long story short i am now installing a new u joint, which i am purchasing from carquest for $12.95, and also installing the new o-ring which is located on the speed sensor on the output shaft.
