I was driving my 1997 TJ to a garage this morning to get inspected when it blew a bunch of ATF out the rear output shaft seal on the T-case. I'm trying to figure out what happened. Please see details below.
I just got this thing on the road after having replaced a broken T-case tailshaft housing and bent main shaft (previous owner lost a rear d-shaft on the highway). Installed new rear output shaft seal and slinger. Also installed a hack-n-tap SYE and dual-cardan rear d-shaft.
I test drove it around my place and on some country roads up to about 55mph. No vibes, no leaks. This morning drove I-40 from Burlington to Chapel Hill at 65-70 mph, and just before reaching 15-501 my wife called to tell me the Jeep was smoking (she was following me). Pulled off at the exit ramp to see that ATF had blown out of the T-case rear output seal, and was all over the d-shaft, exhaust, rear axle, etc. Limped it REALLY slow the final 3 miles to the garage for an inspection and left it there. Will pick up with a trailer and haul home (lucky for me I know the guys and they'll go ahead and inspect it for me).
What I'm trying to figure out - what the heck happened?
Could I have a clogged T-case vent, and it caused the fluid to blow past the rear output seal once the T-case got hot? I know the new (used) main shaft is good and the seal was put in right. The t-case was out of the Jeep for a LONG time waiting for me to fix it, so mud dobbers could have clogged the rubber vent hose, which was left open, still attached to the Jeep (happens at my place all the time to any small hoses left open, like an auto trans cooler line or an air compressor hose).
Any other ideas, while I'm sitting here at work worrying about it until I can get it home and check it out?
I'm so sick of working on this thing - I hope it's something simple and I don't have to pull the T-case again.
Thanks!
Richard
Could I have a clogged T-case vent, and it caused the fluid to blow past the rear output seal once the T-case got hot? I know the new (used) main shaft is good and the seal was put in right. The t-case was out of the Jeep for a LONG time waiting for me to fix it, so mud dobbers could have clogged the rubber vent hose, which was left open, still attached to the Jeep (happens at my place all the time to any small hoses left open, like an auto trans cooler line or an air compressor hose).Any other ideas, while I'm sitting here at work worrying about it until I can get it home and check it out?
Thanks!
Richard
