jeep9mm
- Mar 20, 2005
- Charlotte, Wilmington
Okay...so I had been saving up for a winch and I had it all lined up and then phone bill came up and rent and other stuff and I could not afford a tmax from the good folks at CRS. Then I got a pretty good deal on a mile marker PE 8000...and Ive heard bad things, but mostly about being slow, and for what I will use it...slow doesnt bother me. I also read some good things and I believe and hope that for the 15 times a year I have to winch, it will hold up...so i ordered it and a tleast in the box the quality looks to be good, it looks very well built.
Anyway...lets talk about batteries. Remember I will only be using it about 15 times a year...to winch others and myself. It is a 2004 TJ with a 2 inch lift and 31s so not a lot of weight about 3600 tops. Am I straight with my stock battery for that kind of use or should I go with something stronger. If I should would an optima red top be okay or if your gonna winch you might as well go bluetop or yellow top? Oh and is it true that the latter two are exactly the same except blue has longer warranty bc it is intended for marine use?
And winching essentials...a good pair of gloves, a tree saver, a shackle? Do I really need a snatch block? Do I really need chains? Anything else? If you've seen any good prices on any of the previously mentioned accesories let me know..
thanks guys
Rod
thanks guys
Rod
