I originally started this thread about a week ago on RCC. Figured I would paste it here.
If anyone is going to give me crap about my welds (specifically where I welded the rear frame hoop to the b pillars... had a few too many Yuengs and kept missing the joint) and chassis design in general, I'm guessin' it's going to be you 1:1 guys hahaha. First attempt at any sort of chassis build. Turned out okay but I'm not going to get too picky about this chassis. Just wanted to build something that will take some abuse. The frame isn't perfect, but it's square enough for an r/c. Before I build another "tuber" I am going to build a jig for the main frame rails and a decent bender.
At this point the build is far from done, but I have a rolling chassis at the time of posting this.
Alright, this is based off of a Venom Creeper. I was sitting here staring at my Creeper kit. Not having electronics currently, I decided to start cutting and bending up a chassis. What I have so far is below....
I am loosely basing the tubework off of the factory Creeper body although I am enlarging it a bit.
First attempt at a full tube buggy. I have owned/assembled both a First Gen AX10 and a First Gen SCX10 so I know my way around these things a little bit...
No plans for interior yet. Will at least become a one seater with a simple interior at some point. Want to get the chassis built and electronics installed so I can test it. I am also going to have quite the puzzle on my hands once I go to install electronics as I am building this entire chassis with no electronics to mock up besides an RX.
Inspiration comes from years of reading full scale and small scale buggy/truggy/whatever build threads...
Also inspired by -
And....
I started off by doing this... I know everything is janked up in this picture and far from square.
Then I decided to stop while I was ahead and do this.
YES I know that I need to even the two main frame rails out. Everything will be filed to fit before I go to weld it.
Now it's like this. The fenders will be raised a bit before welding.
BTW I noticed that mocking stuff up and trying to get it to stay square for a decent picture is a total paint in the arse!!!
That's all for tonight...
Did some welding for the first time in nearly a year...
Added 3/16" plates to the corners of the two main frame rails for mounting points for the A and B pillars. Another reason I built it lower is so that I can get a nearly flat belly. Skid will be made from some scrap aluminum I have laying around. Excuse the ugly flux core welds. Ain't pretty but they'll hold. They might get a bit better as the build progresses and I get back in the groove of welding.
I only brought the Creeper out there to get a little farther with mockup. Not welding around it.
Kind of at a loss here... Not sure if I should build front and rear frame sections first or just do the front fenders and go from there? This thing is going to look weird because of the shock mounts. Currently don't have any long hardware to move the lower shock mount beside the lower links.
Any input is appreciated...
I have a TON of grinding, dremeling, and filing to do already (throw the high chance of needing to add some more weld) and I would say I'm about 30% (?) done with the chassis as far as "tube" work goes (3/16" rod btw). I have to weld outside and the sun just went down not too long ago so I came inside to upload some pics, update the thread and start cutting some braces and bars to finish out the chassis.
Shock mounts are currently up in the air. Going to mock them up on the lower links tomorrow. I have bolts that are long enough to slide the shock mount on beside the lower link mounts but they are a couple mm's too short to let the nut start...
Excuse the ugly welds but I am way out of practice and flux core is lame.
Onto the pictures.
VVVVV I ended up ditching the front brace and trimmed the front bars some after taking this picture.... VVVVV
After the final welds of the day....
Mocked up. Not sure what to think. I may have to tweak and/or cut the rod near the servo. We will see. Looks like it's going to be close.
It's difficult to get a Creeper skid to balance on a flat surface....
Still need to figure out what I'm going to do for upper link mounts. Want some adjustability but don't want to drill 1,000,000 holes with my sad drill bits and no drill press.
Also inspired by -
And....
Onto the pictures.
