wireless network
I have a linksys router and looked at that. I wondered how well it worked.
anyone tried the antennas I have seen on ebay?
I've used the repeaters before. They work great. It will essentially give you the same range that your router currently gives you. Never tried the antennas.
Hahah, my sister does that too. Cracks me up when she shows up at the house and says her neighbors signal isn't strong enough and she needs to borrow my PC to do her college work. :p
Buffalo has a nice one that was supposedly using the linux open wrt code. But I can't tell if that's still true or not.
J
I have one of these running dd-wrt. You really can't beat it for the price. It's got at least one USB port on the back, so I put a memstick in it and mounted /opt and /tmp there, added some local dns entries into a whitelist file on /opt. It's only usb 1, but that's fine for low-bandwidth stuff.
You can always check here. They show a Buffalo WHR-G125 and of course the Linksys WRT54GL.
DD-WRT is definitely not suited to mass adoption, but if you want to geek out on it a little, it will definitely do some cool stuff. Mine can act as a NAS via cifs shares (although it doesn't currently), it does local dns caching with a blacklist. It does some traffic shaping, bandwidth monitoring, ddns, probably a couple of other things I'm forgetting.
I understood the word "geek"...
I have one of these running dd-wrt. You really can't beat it for the price. It's got at least BLAH BLAH on the back, so I put a BLAH BALH in it and mounted BlAH BLAH there, added some BLAH BLAH into a BLAH BLAH file on BLAH. It's only BLAH BLAH, but that's fine for BLAH BLAHstuff.
You can always check here. They show a BLAH BlAH and of course the Linksys BLAH BLAH.
BLAH BLAH is definitely not suited to BLAH BLAH, but if you want to geek out on it a little, it will definitely do some cool stuff. Mine can act as a BLAH BLAH BLAH(although it doesn't currently), it does local BLAH BLAH with a BLAH BLAH. It does some BLAH BLAH shaping, BLAH BLAH monitoring, ddns, probably a couple of other things I'm forgetting.
let me translate that back to you so you can see what we see.
cool info in this thread though. glad the topic got brought up.
Fawk, I'm not in IT. I went to school for architecture. ;)
