BugsandJeeps
Member
- Oct 12, 2006
- Concord
Hi All,
I have been searching the forum for help on electrical issues and have made some headway from previous posts. I am trying to get my 74 CJ5 back on the road. So far I have managed to conquer the headlights, and emergency lights. I have grounded the tail lights individually using a length of wire from the mounting bolts to a cleaned spot on the frame with a bolt through it. I have done the same for the front signals to the grill. I have the backup lights, rear side markers and taillights run with 3 seperate grounds to the same bolt. So there is one per side on the rear.
Problems:
1) Applying the brakes causes all the lights except the headlights to light up.
2) Left Turn signal causes everything to flash.
3) Right turn signal blinks just the right rear taillight.
4) The signal lights or brake lights don't work when the headlights are on.
I think I am close as at least I am getting power but I am getting frustrated. I have also replaced the headlight switch and cleaned all the connections.
Any help is appreciated.
Mike
Problems:
Mike
