Jeffncs
- Apr 4, 2017
- Wake Forest
I may need some help from the trust…
I swapped a 98 4.0 engine, ecu and slimmed down harness into my CJ7. My buddy did all of the wire work… and he’s excellent at it.
Here’s the issue. All wiring is connected with 2 relays (fuel pump and auto-shutoff) and the other connections into the Jeep harness.
We can’t get the relays to trigger the fuel pump and I can’t get the engine to fire. The engine spins as expected when cranking it over.
I have an auto ecu and manual ecu. Neither makes a difference here. I’ve checked relays, swapped fuses, etc. Anything you’d recommend I check?
