will my engine run without the dash panel hooked up just the power harness and stuff..
Yes
will my distribuotr get power to run my engine if the onboard panel ..... isnt connected... the senors essentially-
Not sure but you c an wire it seperately if needed.
Ck this out, and do some searching here:
http://pirate4x4.com/forum/showthread.php?t=513313&highlight=minimum+wiring
i want to get it running... i have an alternative starter... aftermarket NOT ON column.. had it hooked up to power with
You mean ignition switch?
