the D35 is as horrible as they sayvery very true. i was just trying to say neither are as horrible as they are made out to be.
d35 has its moments of breakage ive noticed for people but i couldnt speak the same about it. u know, they didn't put it on the jeeps for such a long time for nothing and the stock cheorkee isn't so capable for no reason so.....i think there could be more credit given to them than 'horrible' . Take a stock cherokee d35 against bone stock to any other blazer, exploder,bone stock and give em all hell as far as they'll go and guarantee others will brake stuff before jeep does, id put money on that bet, ive seen it
My experiince with the D35 was the classic tube flex/shaft breakage/wheel+shaft walk out.
I agree myself as far as wheel it like it is for now, don't go crazy on those diffs and wait until u have enough money to upgrade a worth upgrading setup. That's what I'm doing now. Even on 38" Cut TSLs, I'm just gonna take it easier until I get money for a big upgrade and then be done with it. Have fun, don't be too hard on it and save up. That's what I've been taught and that's the route I agree is the best to spend money on.Question for the OP... do you have a welder or access to a welder and are capable to performing an axle swap yourself? If not then stay with stock axles. If so, the sky's the limit. if you only want to run 35's then stock axles should be fine. You're at a point where it's either jump or don't jump. You're gonna have a nice chunk of change invested in an axle swap regardless of what they are and one day you'll regret sinking money into anything thats less than 1 tons. Stick with stock and get some trail time in. They won't be around forever.
Waggy 44 in the front, XJ 44 rear
