- Sep 28, 2009
- Concord, NC
I'm having problems getting a stiff pedal out of the XJ. I have tried everything and don't know what else to do. I'm hoping one of you can help out.
All brake components are stock except I'm running rough country extended braided brake lines. I replaced the master cylinder thinking it was going bad. Doing so gave me a little more stopping power, but it still wasn't right. Until a couple days ago I wasn't able to get a hard pedal and had to constantly pump the brakes to get it to stop. I found a leak on the rear axle where the line drops and bolts to the axle. After fixing the leak the brakes were bled again until no air came out. I now can get a decently hard pedal after about 2 pumps. There are no leaks on the calipers or the wheel cylinders. All the brake fluid comes out clean as a whistle. We've run about 1 to 2 large containers of DOT3 through it with all the bleeding.
What else can I check? Parts stores don't show a proportioning valve so I'm assuming it doesn't have one.
