muddyjeeps27360
- Aug 5, 2007
- thomasville
Does anyone know If these things come out and how.
Thanks
Thanks
No the trick is to makes sure they line up with the pin or bolt in there. Then when you pull the pin they should line back up fine.wouldnt they be hard to shut and line up properly? Just trying to get the info as I want to do the same to my xj.
98 they changed the hinges and requires a little cutting
Depends on the manufacturing date I guess. Done a 97 and it had the old style hinges.Believe it was '97. Mine required a bit on my '97 and that was the year of the big redesign.
