89wrangler
Not a new member
- Oct 22, 2005
- Bostic,NC
99 XJ issues, 4.0 / AW4
1) check engine light on and no reverse lights, getting a P705 code. From my research this is normally caused by NSS. Tried cleaning the one on there, but that did not work. So I replaced it. Adjusted it so it starts in park a d neutral, but still no reverse lights (bulbs are good) After erasing the code, went for a drive and the light came back on and still have the P705 code.
2) once I start vehicle in morning and take off, trans will not shift into 4th. If I turn off engine and restart it, the trans and lock up converter operates as normal. This is consistent each morning. Any thoughts what may be casing this?
thanks in advance
thanks in advance
