Yeah there is a check valve integrated into the pump. You can check whether it's pressure regulator, injectors, or pump by blocking off the pressure line with a gauge. Watch pressure. If it holds on the supply line, pump & check valve are ok. If you block off the return line, you can check injectors after checking the pump. If that holds, then it must be the pressure regulator bleeding pressure. Rule of thumb is half the specified pressure in thirty minutes (39 psi for return systems, 49 returnless) . If it's returnless, the regulator is part of the sending unit and if it leaks down with the gauge at the pressure feed, replace the whole fuel pump unit, and it'll fix it. If that tests out ok, and then pressurize the system and it leaks down, pull the fuel rail, and I'll garuntee you've got a leaky injector. Which will eventually lead to a failed converter.
