XJ on tons????
MidwayJeremy
Member
Huntersville, NC
What kinda track bar is everyone running on the xjs with d60s?
Curious if anyone running a Rustys, Ironrock, Rough country setups? or will they even work or be strong enough?
I would talk to Ironman4x4
NC4x4 Vendor
ECORS Sponsor and Competitor
Heard great stuff about there products, though haven't been fortunate to use any, did see some of there shackles recently and was fawkin impressed.
I really like the Clayton offroad trackbar setup with the johnny joint setup...
the trackbar is fairly easy to source or make stronger than stock, any of those listed are quite stronger. The frame end is a little weak due to the unibody.
Custom DOM and TRE's aren't that bad to fab either (for the steering).
I would advise beefing up the factory steering box frame area also, another known weak spot.
Unless you run a narrowed 60 up front that's close to stock width, then you'd need a custom track bar. With a substantially wider axle you'll have a longer drag link to the passenger knuckle or hi-steer arm. So you'll need a longer track bar to keep the axle and steering moving in the same radius. With the longer trac bar the axle mount will need to be moved closer to the passenger inner C to keep the axle centered. Hope this makes sense. Just my 2 cents.
Ive ordered the frame stiffeners from HD offroad enginneering... I ordered the full stiffener package front bumper to rear bumper.....lol
Mars- once I get everything mounted and im ready for track bar setups I'll give ya a call and see what we can work out....I def gunna have to figure out something thou there.....
Sounds good man, just let me know when you're ready.
def will do! I have some other ideas too Id like to get ur opinion on.....I'll be getting in touch with ya b4 long
