a_kelley
mechanical fixer
- Jan 26, 2010
- Rutherfordton
Easy way to swap powertrain in an XJ.... all at once.. I would not recommend pulling it with the T-Case on it... it got hung up on the trans tunnel but a little prying got it.... I'd drop the tcase if I were to do it again. (likely will before it goes in.. but the one nut inside the shift bracket is hard to get to, so maybe not) oh and roll the jeep out from under it, not the other way around, unless you have the privilege of working on level, smooth, concrete.
click to enlarge
click to enlarge
