xj xtened brake lines
mileshigh
Charlotte NC
anyone had any problems installing the front extended brake lines on a jeep cherokee. The rear was easy but i cant seem to get the hard brake line to unscrew from the old rubber hose... any help would be great or any tricks i could try
if you can't get them to unscrew and you have tried using vice grips which worked for me then you could replace the whole line and just take off at the master cylinder. I would try using two vice grips first, my jeep is an 84 xj and those where a pain in the a$$ but the vice grips worked well.
YEa i finally got them lose with two pairs of channel locks but it was no was no easy task to say the least...i was starting to heat them up with the torch but then i thought better of that idea!
