hunterdan
- Apr 13, 2009
- Morganton,NC
I just installed a new 20 gallon poly tank and new sending unit. It registers properly but if the fuel is rocked it will max out. If going down a smooth road it just moves around slightly like it always did. The original harness side had a 3 prong connector. The sending unit side had a 3 prong connector with only 2 wires because of no fuel pump. At the moment I have the tank on the ground wit elec. connected.
So far I have run a ground straight to battery
Looked like the float arm was kind of sloppy and I thought the connector that changes ohms was loosing contact so I bent it a little and still no go.
Any ideas appreciated.
87 wrangler/4.2 carburetor
