Your favorite TJ Axle swap brackets (who's and why)
scotch737
Greensboro
Any fabbers out there that have messed around with different axle brackets from different companies please feel free to tell me what you used and how you liked them. (This is for a TJ with short arm suspension)
I have done alot of searching and found many. I like the ECGS rear set, good price. My problem is not shopping, just wondering if you had a good experience with a certain brand. Keep in mind, my front axle is 2 and 3/4 tube and rear is 3". I know I might have to "modify" or massage them slighty. Thanks for any input that will help me make a choice. As I am getting them shortly.
Thanks,
Josh
Have you tried artec I got there replacement lower control arms for a Dana 30, Barnes4wd is always a go to for brackets and what not for me
Sorry forgot the why artec brackets key off existing brackets on axle if staying with a Dana 30 and Barnes brackets are beefy
Just ordered a couple pair of lower brackets from Brad Barnes today.
I used Mudpro for my front lowers only because I kept my cam bolts for alignment purposes and Mudd had provisionsome for the cams and Brad (barnes) didnt.
But can't say enough hood about Barnes, when I called him he actually told me to call Mud once I explained what I wanted.
Thanks so much for the quick feedback. Reason I love this forum. Guys I know I can trust to give good info. Still pondering on making the lowers myself, and just buying the spring buckets
Artec.
I have used brackets from Clayton with great results.
Also used Artec, which BTW, had amazing customer service when I had a small problem.
Sent from my SM-G900V using Tapatalk
Support your local guys !
