zj alltime 4wheel drive swap to wrangler or cherokee
wncmtnrunner
Joined the Band
Banned
flat rock
can i swap the transfercase or tranny and transfercase out of a wrangler or cherokee into my 94 zj and how much would it cost. or is there a better/more bang for your buck swap
what engine do you have in it? you can swap a 231, 242, 241, etc from a XJ, YJ, or TJ into your jeep... just make sure you have the right input spline count to match your ZJ...
another stronger option is swapping in a flipped d300, but itll cost you more...
if you have the V8, then none of the others' trannys will work, and that is your weak link... if you have the 4.0L, iirc you should have an AW4 which is an awesome tranny... if for some reason you have the 4.0L and dont have the aw4, then you could swap in one from an XJ...
^ ZJ's never came with aw4 i dont believe. they all came with something else, even the 4.0s...i cant remember what the tranny was though. i am sure somebody else will chime in.
but yes if your ZJ had the 4.0 you should be able to swap transfer cases...no idea on the cost though. probably fairly cheap if you already have the cases etc etc
i have the 4.0 with the alltime 4wheel drive would i be better off swaping the aw4 and np231 and i would get better gas mileage right? Also does any one know who can do the swap and how much does it cost.
