BigClay
Knower of useless ZJ things
- Sep 24, 2008
- Winston-Salem
Has anyone on here put a quick release steering wheel in their rig? Any TJs?
Wanna keep your airbag intact and functional?
Why do you want to remove it? Anti-theft?
) so I was thinking a removable steering wheel would make it easier to get in and out.Shouldn't need a horn button on the wheel as long as you have one accessible from the drivers seat. I have a delivery truck that got a short in the column and it ate 2 horns. My mechanic said it would be easier and cheaper to put a button on the dash rather than pull the column. It's passed inspection 4yrs straight like that!I am planning on hard mounting my seat and tieing into the cage like I did in my ZJ. Since I have to be able to get the clutch all the way in, I am going to be really close to the steering wheel (you know, because I am not a little guy and I may or may not have a belly getting in the way) so I was thinking a removable steering wheel would make it easier to get in and out.
Removable steering wheel is a huge help for fat people. My other fat friend has one and its the only way to go with a fixed seat.
^^ same here. The NRG hub is legit; no play at all in it. I have the hex style on my jeep and it has some play in it; the NRG on the toyota locks up super solid and centers itself automatically.
My seat is hard mounted and I can still fit, the steering wheel isn't my problem. It's the cage I always hit getting in or out.
Was your Jeep a TJ by chance?
Yes it is. How come?
Forget QR wheel at home the next time you go wheel and regret adding one
^Been there...done that. Good thing the house was only 30 min from Mtn City.![]()
Unhook battery
Remove airbag'
Remove steering wheel
Install (weld) quick release hub to steering shaft
Pop new wheel on hub
