The first image had one and i just wasnt a fan not mention any rear overhang will definitely get smashed at the size this will be. Trying to be "realistic" with fitting something this big on trails haha.
Fwiw I'm running the full length unbobbed bed on my Tacoma and I can count on one hand how many times I ever got hung up because of it, and usually it was due to my poor line choice. Cut the bumper up high and run some tube around the bottom of it and drag that bitch all over the SE!!
Haven't looked that far just yet. Seems most people who are running 14 bolts or other axles without vss are also running plder transmissions or manuals thst dont need the signal.
End use Is a goal. But man that render with the bed is sexy. Build it nice looking either way your gonna raisin that body on a lot of trails. If you start out sexy at least it was like the young girl once,
Im bouncing back and forth at the moment between leafs or single triangulated 4 link similar to the moms spaghetti f350. I like the idea of air shocks and being able to dial in height and spring rate. But still need to do some research on them to see if they would be ideal for something this size.
I'm thinking you might be able to go with a 91 or earlier speedo gear and sensor and pick up the transmission signal from there. It's been a long time since I've messed with any of that stuff, but I know people would put sensors on the driveshaft to do it, or even just run without one entirely. This suggests there are other options too:
Thats definitely an awesome option! I figured it needed the vss for the shift logic. Not sure how it would behave without it. Possibly just shifting off rpm or pressure? Thanks for the link!
Pretty simple but better results if you pay for the extra prompts. Im usually limited to like 6 pictures a day on the free options. But the better your prompt is the better your picture will be. The more reference photos you can supply the better the render will be. For example my original "vision board" was 100% prompt based and not 100% accurate to my goals but close enough for getting the image out there. Once i used a vehicle as a reference and prompted, i was able to fine tune it and have a more realistic real world render drawn up. And just needed to add "remove a bar on the roof rack", "keep the same stance but increase tire size". Oh and always be polite to our future ai overlords. Please and thank you go a long way . Ill attach another prompt i did using my buddy's k5 as a reference for a truggy build.
For both of my examples my base prompt was simply "Use this k5(bronco) as a reference. Add rear doors to make it a crew cab. Keep the rear tire as close to the cab as possible while allowing full articulation of a 40" tire. Keep the body style as a squarbody (80s ford). Thank you."
Then as each render was made i would add on. For example my bronco i used the prompt "take this reference and show me what it woild look like with an exocage and tire carrier using the red lines as a reference. Also a stinger bumper using the red lines on the front as a reference." Then i just fine tuned aspects i wanted or didnt. Theres whole videos on prompt engineering that i would like to look into to get better outputs but this is a great start for someone just slinging ideas out there.
I pissed it off, lol. Said I used all the alloyed time on Goggle AI. I must say you have created a monster. I am going to explore Chat GPT more after playing with Google. It was a little clunky and my brief look at Chat GPT I think it has some features and menus I like better.
Playing around with some 4 link calculators to see how things would look if I did a single triangulated inverted rear suspension and a wristed radius arm front with a removable pin on the passenger side. I think these numbers are looking ok? Still a ways off, but wanted to mess around with proof of concept on something i've never tinkered with.
I keep tossing the idea of the kingpin vs the super duty 60 back and forth. Talking with a buddy and hes pushing the kingpin 60, but im just not seeing a massive reasoning to keep it vs the benefits of the super duty 60 in my research. Any input from anybody wheeling both? Fairly certain im either going with 3 link front or "wristed" radius arms with a removable pin for the upper link, either way. Going to ditch the leaf springs. My thoughts right now are figure out what the kingpin 60 will sell for, hopefully enough to cover the cost of some 05+super duty axles. Theres a '16 superduty that just got dropped off this weak at the local u-pull if i wasnt expecting a baby any minute id be tempted to run and snag the front. Open to hearing opinions. Most comparisons ive found and forums are 10-20 years old at this point so i know theres gotta be some updated experiences out there.
Personally, I would 100% go with 05+ Super Duty axles. Cheaper to build, stronger in every way and is basically the new standard that everyone builds parts for.
Kingpin is only stronger if you use aftermarket knuckles (Reid, Crane, Solid). Plus, you can put ball joint eliminators in the Super Duty ones. I don't see a need for it, but I'm not bouncing off a rev limiter and trees/rocks at the same time.... usually.
Some more goofy concepts and ideas floating around my head. Any input on an external "rub rail" to protect the roof line above the doors in the inevitable event of it coming into contact with a tree or rock. 1.5-1.75" tubing welded along the roofline every few inches top and bottom. Truck will have a cage so it doesnt need to be true rollover protection just less likely to make it where the doors wont close haha. My reasoning or thoughts on this being doable or making sense, is that i dont see how its much different than a 2x6 slider welded into the rocker like my bronco or how squarebody guys do. And this wouldnt need to support the entire weight of the truck like those do, just spread the load and offer a smooth transition? My 2x6 sliders on the bronco are only welded on the sheet metal and i can pick the entire truck up using them so i guess im thinking this should be substantial? I coild even drill plug weld holes and weld from underneath if that would make a difference? Basically a baby exo for body protection not rollover protection. Just spitballing ideas to make the cab last as long as possible.
Does the truck have a drip rail? Kind of hard to tell from the pic. But I think something smaller laid on top of the drip rail would look cool and serve your purpose. Something like an inch or so? I think 1.5-1.75 would be overkill and stick out to much IMO.
