- Lack of/too little gear oil
- Improper gear setup
- Bearing(s) toast
Amazing enough, the same things that cause "odd noises"!
hm...
-new gears from Chase, had same noise on prior 2 3rds - just slowly getting worse
-literally just changed oil (had the 3rd out for fixin ga leak and e-locker wiring issues)
-hmm possible? But seems odd given the behavior, see below
Well I was going to start a seperate thread for this, but here's the deal w/ the noise.
It's kind of like a sliding/grinding sound, ONLY occurs right at the transition point between applying gas and coasting. Auto tranny btw. Pedal firmly pressed - no problem. Coasting - no problem. If I very lightly feather it, like you might going slightly downhill, then it will persist the whole time until either letting off or pushing down to full-on threttle.
Def gets louder w/ speed, at like 25mph it's bearly audible, noticible at 45 and loud at 65.
No vibration, just grinding noise - I can kind of feel it in the floor (at high speeds). It sounds alot like a pice of metal sliding inside another piece w/o lube.
T-case to pinion angles fairly normal.
First noticed it years ago w/ first mild lift on back end, but was very subtle and I choked it up to AALs and shackles offseting pinion angle. It's been slowly getting more andm ore noticible - over that time I've changed 3rd members completely twice and that never made a diference.
No longer using AALS or long shackles.
I can only think 2 possibilities now - output shaft bearings (UGH!) or maybe wheel bearing(s). But I'd expect wheel bearings to be constant?
There was a very slight wiggle in upper u-joint, just replaced it - no change, but did eliminate a slight vibe I was getting)
