How much have you towed before ?
I've towed several Link Belt 220 excavators... they weigh about 75,000lbs (75 THOUSAND) and are just under bridge height when tucked.
stock truck :flipoff2:
Yeah, towing heavy equipment adds up fast. We had a case trackhoe with 60' reach and articulated dump truck brought up the mountain when we dredged out our snowmaking reservoirs, that was probably close to 150-200k lbs of equipment. Left some SERIOUS gouges in the pavement at a set of tight S-turns, took a police escort and then some to get them up. Don't recall the setup but it was def a tandem that lugged them up.
Fun machines though, the case truck probably could've fit the f-750 we'd been using in its dump bed. We also had a daewoo 010 solar compact excavator at the time so we had a trackhoe that would actually fit in the bucket of the big case (cx 350 or something like that).
heres what i tow on a daily basis
these mixers loaded weigh up to 91k,this one had a broken drag link
Keith, how much torque/horsepower does that tractor have?
its a 500hp 60 series detroit(not a detroit fan) company truck but she'll pull,i cannot recall the torque,i do know its got 390 rears with a 10 spd tranny(wish it was an 18)
Looks like small time for me:
Bone-stock '06 Hemi 2wd LB CC 2500 with my 7k 16' loaded with my Frontier out to Arizona in March. Was probably pulling 6.5k with a load of gear in the bed. With the Reese SC W/D hitch and electric brakes the thing really did let you forget you were towing anything. Of course to most of the people on here, it was like I wasn't towing anything!
this wasn't heavy but it was stupid......Unbreakable and I did this yesterday
It's a 36' MH frame with no axles...It took a 2inch ball and there was no way to lock it on the ball. We had to take it down the road about a 16th of a mile and then turn around on a side road.
Me and my dad pull 33k on a 34' tandem axle gooseneck pulled it down 321 with his 97 chevy 2500 with stock 6.5..and a 15k tag lol talk about sweating it
pulled a 1000 komotsu track hoe on a regular tri axle low boy witch will only handle 110,000 lbs gross weight (truck,trailer and load) 1000 komotsu weighs 130,000 lbs by itself,got caught 5 miles from galveston where i was headed. had to bring another low boy remove the bucket the stick and the counterweight.
Towed an IH school bus with a 72 c30 and a Uhaul tow bar. Had to have someone steering the bus because I couldn't turn. Went past the local police station, nobody even noticed.
They probably figured the p/u broke down, and the bus was pushing. ;)
towed approx 18k, with another 10k in the bed.
With a M977 :flipoff2:
Nice Jerrdan. How do you like the integrated boom/wheel-lift compaired to the separate units? (I used to be a mechanical designer for a super-duty wrecker manufacturer) I have heard that the integrated boom "moved" a little more due to the pivot point being closer to the cab.
Again...nice tow rig!
It's not a cement dumper, but fun none the less.
This one was back on the trailer this weekend. Suddenly lost all power with bronco on trailer coming down the mtn in Asheville. Never would even try to start, just crank, crank, crank. Replaced CPS, took off chip, nada. Turns out the IDM died. KB6677 drove over to Johnson City, TN this morning for me to pick up a new IDM so I can go to Gore for the Bronco Roundup this weekend. Thanks KB! That hurts in the wallet though.
02 f250... afe stage 2 intake, 4" exhuast to include downpipe, firestone air bags, power hungry chip. 23,220 lbs. got 10.5 mpg.
wifes YJ, my CJ5 and the golfcart with spinners...
well i beat the 23,220 lbs...
4,580 miles... 25,640 lbs... KOH and back... 8.5 mpg avg.
now i know i met up a few folks, and i think they were from here... anyone remember meating up at a fuel up? i think it was on I10 out west. this might jingle your memory.
use to leave new york going to san fran grossing between 110000 to 130000 about twice a month for around 7 years.not a big deal till you get out west going around the scales in the rockies.(makes black mountain look like a speed bump) once hauled a komotsu 1000 track hoe only about 2 miles on a regular lowboy. a 1000 komotsu has to be disasembled and does not fit on a lowboy.it must be hauled on a rail trailer because the tracks are too wide to fit on a regular lowboy. it weighs around 165000 lbs.we walked it sideways on a lowboy and away we went for about a mile and got caught,boss man ended up in jail because he could not keep his mouth shut,company paid nearly 6000.00 in fines,but we got it moved without calling in their hauling rigs.
used to tow a 38' toy hauler with a Dodge 2500 24V/6-speed/5th wheel. When fully loaded with all the racing gear, the trailer was just over 20k. Towed nice with the Dodge and the 5th wheel.
f350 dualie and a 28klb 40ft goose
7400lbs give or take a couple lbs. 5'x10' homemade single axle trailer pulled by a 1993 ford ranger 4cyl 5spd. I had to end up replacing the clutch in the driveway with the trailer still hooked up. :-(
