''ZUKOTA''
zukduk
VALDESE, N.C.
This is what i've beenworking on for a while.... Its a Suzuki based buggy w/ 2.7L Taco engine and Megasquirt II stand alone fuel managment system....Dana 44 front and dana 60 rear w/ Detroit locker....38.5 x 16 x 15'' Swampers on custom 15'' rims w/ my beadlocks. Everything on my buggy was made in house w/ a CNC plasma table....18'' Fox 2.0 air shocks.(that i dont have yet) Have done alot of body mods that only a sami owner could probably detect.... I'll keep you posted..
I can't say I ever saw rear lower links like that. It looks to me as if they will last a lot longer because they are up out of the way, and as said, beefy. Can't wait to see it out on the trail, let's see, it's the end of 2010, so I am thinking 2013???
Worked till 3am building my transfer case mount in w/ crossmember but got it done. Set the body on it to build center well to fit trans. Going to have to cut rollcage from front to fit body back in after paint tooo tight....Sent my dash board to get Hydroprinted w/ reeper skulls (awsome ya'll need to check this out!)www.carolinahydroprint.com
This is what i am having my dash finished in (Hydrodipped)Should i do it w/ a matte or gloss finish cant decide....
man that cage work is sick. this toyami is gonna be nasty. what gears you runninin the axles or did i miss it
4:10 gear 60 rear and 44 front.....
SICK ASS foot pedals.....took awhile to make these but it turned out sweet....
Haven't done anything to my sammy had to fill christmas orders but soon i'll be back on it going to try to finish cage up and build floor pan to fit shifter....then i think i can start painting going w/ sublime pearl green body and silver frame and cage.....I'll be back.....
whatsup, its trevor....i bought those lockers for a samurai from you here a few weeks ago, just wondered if you had gotten any closer to pulling that transfer case and motor and everything out yet
Not yet still putting the motor together might be a few months yet ill let you know when its done....thanxx
Anybody have experience w/ manual brake pedal assy. what kind of master cylinder should i use for the easiest pedal have to remove booster because of intake room....Have disk brakes front and rear.....need to know.....
