Low beams on my Samurai aren't working
kevin061686
Browns Summit NC
I have a 92 Samurai, the low beams are hit or miss, the high beams work fine. I traced wires looking for loose connections or a short, I haven't found a thing. Could it be the light switch itself? Thoughts, comments, feedback, help!!!
Thanks
Kevin
Check the fuses. Also, they're known for bad grounds. Check and clean all your grounds underhood. And again, check the fuses. There's one for each headlight. If one blows, they both go dim. It's weird.
Yea, it could be the dimmer switch. Not sure how Suzuki does it, but I had to replace dimmer switch in my 4runner build cause the wiring broke off the switch itself and I couldn't get it to stick soldering it. (I replaced just the dimmer part inside the switch housing.)
