Who would you call to finish a rig?
drkelly
Dipstick who put two vehicles on jack stands
Oak Ridge/Stokesdale, NC
My Jeep will never get finished if it is left up to me. I finally got fed up enough to call one well known and respected builder MANY months or more back only to find out he was getting out. Then I didn't do squat. Today I called another very well known and respected builder only to find out that as of today he is backed up through the end of the year. Who would you call to finish your rig if you were ready to 'call the man'. I would prefer less than 2 hours from Greensboro. For some reason I find it hard to do this. It feels like failure.
Do you enjoy building or wheeling?
That answers your last question.
I struggled with the same with finishing off my mustang now 8 years ago. I can tell you I have never, not once, had a moments regret with the choice.
If I were in your shoes there is only 1 person I'd call, and I assume he is one of the two you called, and that's Chris Marshall
I definitely don't enjoy the building as much as I use to. I haven't wheeled in 8 years, and would like to finish this Jeep and take my son wheeling.
Agree. I made the call last week, then waffled on 4 weeks out (But I do have an event I want to make in June and it probably wasn't going to be ready) and when I called back, someone else had committed so I was more weeks out! lol
But I jumped in hard this weekend and made a splash. It's not failure, it's life. Get your rig done however you need to so you can enjoy it.
Just come borrow mine. It works but I never use it.
Depending on your timeline, I may or may not be the right one to talk to.
I have a full time job, and do the “offroad stuff” on the side. I enjoy it. I’ve currently got 2 in the shop, one outside and another 2 in the wings.
What needs to be done? Do you just need a jump start to get you back in the swing of it, or are you looking turn key?
There are many talented fabricators in our area, all of whom are worth their salt and their calendars reflect that.
I will pm you tomorrow with some details. Thanks.
I wouldn't hesitate to call PJ at M&M.
PJ is awesome, but the last time I spoke to him about schedule, he was so booked he wasn't really taking anything else on.
As far as the rest, Justin, Chris, Cutler...You can't go wrong with any of those fellers, just truly depends on who can get to you in the time you find reasonable. But like Richard said, this is no failure. Even the best can find it difficult to go out in the garage and find motivation.
Hell, depending on what I've got going on, I choose the easy route a lot of the times and take my truck to Andys in Kvegas for an oil change instead of spending the time to do it in my shop.
@drkelly what all do you need done? I think depending on what you need done, could possibly determine who to recommend.
@MarsFab is much more interested in doing fab work than electrical/wiring or mechanical work.
I need a lot done. This is the list I created.
Jeep work to be done:
Front axle:
  • Weld passenger spring perch to axle tube
  • Install diff cover and fill with fluid
Front suspension:
  • Weld spring hangers to frame
  • Cut shock hoops to length and weld to frame
  • Weld lower shock mounts to axle housing
  • Mount shocks
Rear axle:
  • Weld spring perches to axle tube
Rear suspension:
  • Mount shocks
  • Build traction bar (Have Barnes kit and some custom made parts, rear axle mounts done)
  • Finish building traction bar crossmember (Have parts)
Fuel system:
Mount fuel filter and connect remaining lines after welding spring hanger to frame
Cooling system:
  • Finish building mounting system for radiator (Griffin combo unit with radiator, shroud and fans)
  • Wire up electric fans
  • Install radiator hoses and fill system (need to buy hoses/parts for this)
Steering:
  • Drill and tap steering box for hydro assist
  • Plumb hydro assist lines from box to ram
Driveshafts:
  • Get front driveshaft lengthened
  • Install front driveshaft
Skid plate:
Fabricate a flat skid plate and install
Brakes:
  • Install 1 ton master cylinder
  • Install new brake lines at all four corners and to and on rear axle
  • Bleed system
  • Rear calipers might need replacement (they are old, standard 14 bolt swap kit stuff)
Tub/body:
Build new sheet metal floor around transfer case where cut for clearance due to raised TC
Seats:
  • Build seat mounts
  • Install seats
  • Build mounts for harnesses
  • Install harnesses
Exhaust system:
Build new exhaust system from header all the way back to clear front driveshaft (really need new header due to multiple cracks)
I took the time to compile some estimates for how long it would take me to do these things.
Jeep work to be done:How long I think it will takeHow Long it will actually take
(minutes)(hours)
Front axle:
5​
5​
10​
10​
Front suspension:
30​
30​
60​
60​
20​
20​
Mount shocks
10​
10​
Rear axle:
20​
20​
10​
10​
Rear suspension:
30​
30​
20​
20​
Mount shocks
10​
10​
90​
90​
90​
90​
Fuel system:
15​
15​
Cooling system:
60​
60​
20​
20​
45​
45​
Steering:
60​
60​
60​
60​
Driveshafts:
30​
30​
10​
10​
Skid plate:
120​
120​
Brakes:
45​
45​
120​
120​
Bleed system
5​
5​
20​
20​
Tub/body:
120​
120​
Seats:
Build seat mounts
120​
120​
Install seats
15​
15​
120​
120​
Install harnesses
15​
15​
Exhaust system:
180​
180​
TOTAL
1585
1585
Tim Odell Vice offroad
(minutes)(hours)
Front axle:
5​
5​
10​
10​
Front suspension:
30​
30​
60​
60​
20​
20​
Mount shocks
10​
10​
Rear axle:
20​
20​
10​
10​
Rear suspension:
30​
30​
20​
20​
Mount shocks
10​
10​
90​
90​
90​
90​
Fuel system:
15​
15​
Cooling system:
60​
60​
20​
20​
45​
45​
Steering:
60​
60​
60​
60​
Driveshafts:
30​
30​
10​
10​
Skid plate:
120​
120​
Brakes:
45​
45​
120​
120​
Bleed system
5​
5​
20​
20​
Tub/body:
120​
120​
Seats:
Build seat mounts
120​
120​
Install seats
15​
15​
120​
120​
Install harnesses
15​
15​
Exhaust system:
180​
180​
TOTAL
1585
1585
Unfortunately that is only a slight exaggeration of what actually happens in my garage. LOL.
It’s based on accurately compiled data from my garage :laughing:
I don’t think there’s anything wrong with letting someone else make sure you get your rig on the trail.
I get asked all the time “did you build it” and I never have any problem saying no lol. I just like to wheel more than build. Maintaining a working one is plenty enough work, and that part I do enjoy.
I would recommend @tobaccoroad4wd for a project like that, just gotta be patient. If a man ain’t telling you he’s backed up, you don’t want him finishing your project lol.
I know I'm the last person you want to hear from haha, but for what it's worth I do this full time and I will let my work speak for itself nowadays. I'm not like the other guys mentioned, but I can easily do what you mentioned needing done and I have the time. I can do a full 1Ton build with Coilovers/LS/etc etc in less than 6weeks if I'm not scattering for parts and if you'd like, check out my Facebook (John Fuller) and you'll see all my work for the last many years. I'm only throwing myself out there cause I remember hanging out with you at the Flats and you were always a really nice guy and I have had many people bring me rigs to "finish" for them haha. Best of luck to you, hope you get it done one way or another!
@drkelly the question is do you want someone dedicated to your project and only your project until it's done, or someone who works it in between other projects/day job duties?
There's few full time fab/off road shops around any more and the good ones are booked out quite a ways.
What you want done (decent amount of fab work) is right up MarsFab's alley if he's taking on more work at this time. The other guys who replied do great work as well.
I run in to this with gear jobs all the time. If they want it done tomorrow, I refer them to another shop here locally. If they can make an appt and/or drop it off until I get to it, I'm their guy.
I stopped by @marty79 shop one day to talk about a bumper for my 4runner. Although I have never got around to getting one built, I was impressed with not only his work, but with him. Very nice guy and very passionate about what he does. Had some very clean L's swapped jeeps in his shop that day.
