justjeepin86
- Jul 9, 2005
- Winston-Salem, NC
Just got a quote for 3 10x10 insulated garage doors. Good lord. 14k installed. Guess I'm gettin roll up doors if I proceed with this building.
Check builders discount. My insulated 10×10 was $1,833 in 2024. 12x12 was $2,500.Just got a quote for 3 10x10 insulated garage doors. Good lord. 14k installed. Guess I'm gettin roll up doors if I proceed with this building.
Aren't they insulated inside so you don't have the moisture entrapment problem?Buy uninsulated and foam them yourself?
Yes they make foam board kits to lay in the cavity inside the doors. Or buy a small diy spray kit and do it that way. Honestly IDK the cost difference just throwing something out there.Aren't they insulated inside so you don't have the moisture entrapment problem?
