‘87 wrangler/258 parts
mbalbritton
Orlando, FL
Just doing cleanup and things leftover stuff. Free to anyone on here. Just cover shipping.
Various electrical connectors from the OE harness. OE AMC coil that still runs and tests strong. Aftermarket ECU that worked fine. Vacuum switches for 4WD light and for emissions.
258 parts. What you can’t see clearly in picture is internals like pushrods, rockers, Tstat housing, timing gears and a chain with maybe 1500 miles on it. Timing chain cover, water pump, main bearing caps, harmonic balancer, a couple of pulleys, motor mount brackets.
If I’m oblivious to the value of anything in this, I’d appreciate a heads up. 😁 but I’m thinking that none of it is worth the scrap value.
